Ver.11.0.4.0 Windows / macOS
April 21, 2022
Windows Version / macOS Version
– Support Leica M11.
– Support OMDS OM-1.
– Fixed a problem that black dots sometimes appeared in highlights when the “Clear view” demosaicing engine is applied.
– Fixed a problem that caused the color space to be recorded as sRGB when an image with the output color space AdobeRGB set was used as the representative image and output in DNG format using “Composite selected images”.
– Fixed a problem that caused thumbnails to not be sorted when OK was clicked without changing the settings in the Sort thumbnails dialog.
– Fixed a problem that occurred when changing any settings and restarting SILKYPIX after adding or editing parameters tastes, the added or edited parameters tastes would disappear.
– Fixed a problem that Photo Style selections for “L.Monochrome S” and “L.ClassicNeo” were not saved in the development parameters for RAW images where Panasonic’s “L.Monochrome S” and “L.ClassicNeo” Photo Style were available in the camera.
– Other small fixes.
Windows Version
– Fixed a problem that causes unnecessary folders such as “0000” to be placed in the Recycle Bin when the Import from media dialog is opened.
macOS Version
– The folder tree no longer displays system-related volumes such as “VM” and “Preboot”.
– Fixed a problem that could cause the display of the key setting dialog to be corrupted when a large size skin was set in the Select skin dialog.
List of release history
